Eagleplayer v2.06 OS3
Messaggioda AMIGASYSTEM » mer lug 15, 2020 10:00 pm
Autore: Jan Blumenthal & Henryk Richter
Eagleplayer: Nuova versione dello storico Player per Amiga per la riproduzione di diversi formati musicali altamente modulare, Eagleplayer supporta le Skin di AmigaAMP, Amplifer oltre a due Skin (Standart/24Bit) di EMPY altro grande player Amiga Os3 del passato.
Eagleplayer 2.06: Download
Features:
General:
supports more than 150 music formats including most common sample formats (including CDDA, AIFF, WAV, Datatype, raw formats...)
completely hardware-independent replay system, redirecting the sound signal via custom 'amplifiers' to the audio hardware
supports toccata.library for Toccata, Melody and Prelude sound cards
extremely fast mixing routines
currently supports up to 64 custom programs, e.g. amplifiers,user-interfaces, analyzers, scopes, external depackers, listviews, managers etc.
Sound Features:
carefully and extensively adapted playroutines. nearly all of them support volume and balance, and most common players support the modular amplifier system
replays with 8, 14, and 16 bit resolution (depending on the hardware)
supports free scalable mono, stereo and surround replay
replay speed can be controlled easily, including pitch for several sound formats
music-fadein and fadeout
plays from fastram
System:
supports all common system features, such as ARexx, commodity, appwindow, iconify, asynchronous online help, font-sensivity, pubscreens, hotkey...
supports xpk, xfd, powerpacker, imploder, crunchmania, lh.library and more formats for decrunching and any type of archive may be accessed like a directory
is highly system-compliant and uses heavy internal multitasking
external programs (players, amplifiers, engines) are loaded when needed and removed automatically
CyberGraphX/Picasso are directly supported by some scopes and user interfaces
configuration via configfile, tooltype and commandline arguments
allows timer.device, CIA and VBlank playspeed timing
does not interfere with modem use
GUI:
easy and comfortable configuration that covers innumerous details - window-positions, player and engine settings, current module, each internal and external option will be saved globally with a single action
features different graphical user interfaces with custom boopsi gadgets in the default configuration, some windows accept custom background patterns, multicolour graphical user interfaces up to truecolor (see screenshots)
status information scroller
module info includes playtime calculation for soundformats like Protracker, Oktalyzer, SonicArranger, Jamcracker, DigiBooster and most sample formats
very comfortable handling: e.g. module selecting and directory changing directly using the pulldown-menu
Custom:
random module selection directly at startup
offers a powerful module database, and loads modules lists from nearly all other music players - lists can be handled like normal subdirectories
features the fastest FFT spectrum analyzer ever optimized for 68040/68060 processors. it supports lots of stunning diplay modes.
doublebuffering-function for continuous replay of modules by immediate loading of the next module
the instruments of a soundmodule can directly be replayed and saved in various formats (RAW, IFF, AIFF, WAVE)
can save most protracker-clones in protracker format
supports module ripping, which can be either directed to an interface to ExoticRipper, or to an own ripper.
supports loading of Sound/Noise/Protracker/Startrekker/ Audiosculpture songfiles (that stuff with external samples on ST-00..ST-99 disks)
supports direct Aminet-CD mod archive browsing
Re: Eagleplayer v2.06 OS3
Messaggioda AMIGASYSTEM » gio lug 16, 2020 9:43 am
Eagleplayer è un ottimo Player ma se dovesse capitare che qualche tipologia di Moduli non fosse compatibile segnalatelo come ha fatto un utente su AEB che si lamentava per la "non" compatibilità verso i Moduli "Impulse Tracker", cosa invece non vera, nell'ultima versione probabilmente per dimenticanza non è più presente il Codec "Impulsetracker".
Se dovesse interessare trovate il Codec "Impulsetracker" allegato QUI, nel mio intervento trovate anche il percoso dove copiare il Codec.
