WHDLoad Game Launcher
Messaggioda AMIGASYSTEM » lun gen 14, 2019 4:10 pm
WHDLoad Game Launcher v0.6.1: Download
WHDLoad Game Launcher: Creare WHDLoad .hdf e un HardFile con giochi da utilizzare negli emulatori UAE
Queste le migliorie delle ultime beta:
- Replaced RequestChoice selector with ABS (Amiga Boot Selector)
- ABS http://ohmygibs.free.fr/ohmygibs/Amiga_ ... ector.html
- ABS gives a much better user experience
- ABS has joystick and keyboard support
- Moved bulk of the startup script to ARexx.
- WHDLoad options from .info ToolTypes - using rexxtricks.library.
- Saving of WHDLoad options to .tooltypes file for each slave.
Re: WHDLoad Game Launcher
Messaggioda AMIGASYSTEM » ven gen 18, 2019 2:45 pm
Update WHDLoad Game Launcher v0.7 aggiornamento:
WHDLoad Game Launcher v0.7: Download
With the following changes/improvements:
WHDLoad splash screen is now enabled by default
- Can be disabled in S:WHDLoad.prefs
Kgiconload is now used as the default launcher.
- This skips the ToolTypes discovery processing in the startup script, which may improve launch times.
- Can be disabled in S:/Startup-Sequence
A minimal Workbench is now loaded after a game has ended (i.e. by using the quit key).
- Multiview is launched so that a readme, guide, solution, etc document can be selected and read.
- or by double-clicking a document icon within Workbench.
- JoyMouse is enabled to allow mouse control using joystick
Game.slave file detection.
- In kgiconload mode, user cannot launch game - as the game .info file is not known (or cannot be determined)
- If kgiconload is disabled, then the user has option to skip and launch the game.slave file, but this will be without WHDLoad
options - as the game .info file is not known (or cannot be determined)
- The loaded Workbench can then be used to rename the game.slave file.
Messaggioda AMIGASYSTEM » sab gen 19, 2019 6:38 pm
WHDLoad Game Launcher v0.8-beta aggiornamento:
WHDLoad Game Launcher v0.8-beta: Download
With the following updates/improvements:
Added support for .zip and .lha files mounted on DH1:
- Volume name for DH1: must be <GameDirName>.lha or <GameDirName>.zip, where <GameDirName> is the sub directory in the .lha/.zip
- for these file types DH1: becomes READONLY
SavePath WHDLoad option support added for when DH1: is READONLY
- DH0:WHDSaves is the path used for SavePath kgiconload is now disabled by default
- Since you cannot specify an additional WHDLoad parameter to enable the SavePath option.
- Need a way to change/update the global WHDLoad.cfg on the fly.
