SMBFS v1.117
SMBFS v1.117
Messaggioda AMIGASYSTEM » mar apr 24, 2018 9:12 pm
SMBFS è il Client per gestire Volumi o Cartelle condivise in rete fra Computer Amiga o fra PC ed AMIGA gestibile da una Shell o Filemanager come Dopus4 (vedi screenshot)
SMBFS 1.117: Download
SMBFS: A SMB file system wrapper for AmigaOS, using the AmiTCP V3 API, SMBFS implements an SMB file system for AmigaOS. This file system can be used to access files made available by file servers which implement the SMB protocol, such as 'Microsoft Windows' or any other platform which supports the free 'Samba' product. These files can be accessed using shell commands such as 'List', the Workbench or utilities such as 'Directory Opus' as if the file server were a local disk drive.
This build is a simple compilation from Source Code found on
https://github.com/obarthel/amiga-smbfs/releases
No ChangeLog was provided after version 1.106
Re: SMBFS v1.116
Messaggioda AMIGASYSTEM » mer apr 25, 2018 5:41 pm
Sempre per OS3 per chi non lo sapesse esiste anche un'applicazione recentemente aggiornata che fa le stesse funzioni ma attraverso una GUI intuitiva e si chiama SMBMounter
Re: SMBFS v1.117
Messaggioda AMIGASYSTEM » gio apr 26, 2018 1:06 am
Aggiornata la News alla versione 1.117 uscità a distanza di 24 ore :ammicca:
