DGen: Sega Genesis MegaDrive OS3 Emulator
Messaggioda AMIGASYSTEM » mar dic 19, 2017 4:48 am
DGen è un Emulatore Sega Genesis MegaDrive per OS3 con 020+ RTG ixemul.library 48+
DGen: Download
- build with gcc 3.4.0 (AmiDevCPP) and libSDL 1.2.15
- there is only one thing left to fix - false colors on start of emulator.
fixed by using CTV effect "swab" in included dgenrc.
If you get false colors, use F5 until the colors are correct
- default config file (dgenrc) will be read from current (PROGDIR:) folder.
in case this does not work, use this command line:
dgen -r dgenrc romname
- there are command line options, see dgen -h
